what motherboard do you recommend?
skasol
I am in the market for a new board. I am upgrading my q6600 with Evga 680i to an i7 970 and want to know what motherboard you guys recommend. is there an alternative to the 680i from evga? also it doesn't have to be SLI as I am not going to run dual cards. I am planning on overclocking. thank you for your feedback.
Really I love my EVGA SLI3 however its an older design and lacks SATA3 ports. ASUS Rampage III seems to be a good choice now. I also like Gigabyte boards. Stay away from most other manufacturers well except Supermicro and Intel.
thanks for your reply.
how about this intel board?
Intel® Desktop Board DX58SO Extreme-series
is that a decent board?
Intel boards are rock stable and very reliable but generally do not favor overclocking.
thanks. so you think the asus is a good board? I don't really care for SATA3. this is my 2nd system.it doesn't have to be flashy. is that evga SLI3 a good board? what about x58?
Yes. ASUS and the other manufacturers I mentioned make the best quality boards. I know because I buy dozens of boards for home, work and others.
This is the best board I have ever owned. Even ones for $600 US. I really like the LED readout being built into the board. It shows bios codes before boot then after that it shows the current CPU temp. Although the temp is typically 10C low it is informative.
what about x58?
All lga1366 boards are x58. lga1156 boards are P55.
lga1366 support 3 channel ddr3 ram while lga1156 support 2 channel ddr3
asus sabertooth, sli3, asus p6x58d-e, gigabyte(couple higher end like ud3/5/6), and the higher end msi boards
There are a lot of really good motherboard manufactures, but my continual favorite is Asus. They make superb stuff, and the perk is if you too need support its in the US. I had to RMA a monitor and it was very painless. So far out of 3 system builds using Asus mobos I haven't had one issue. Good for OC'ing too ;)
I will 2nd that, 2 vid cards, 3 motherboards so far all asus, and haven`t had nary an issue save with some of the software side(which is more or less solved now) ASUS support is fantastic even with all that I have done/been through, And they also have many products according to budget and they don`t really go making a bad board for the low budget rather for thier most expensive boards they just add more to them. ASUS is rather l33t in all factors.
Gigabyte is the way to go.. if you plan on doing some "hacking" of the other OS you could do it very easily...
Intel if you want quality and reliability
EVGA for quality stuff, American support, and (usually) good warranties
Gigabyte for bang for the buck goodness
Most Gigabyte, ASUS, and EVGA offerings are quite good these days.
X58 is a very mature platform at this point and there are many that are good.
X58 supports triple channel DDR3 memory if thay makes a difference.
Unfortunately X58 is about done from a CPU choice standpoint, Intel is coming out with new stuff pretty soon.
EVGA makes a number of excellent X58 boards.
If you don't want or need USB3.0 or SATAIII the plain vanilla X58-SLi board is a great board.
For more features and more money grab a "Classified board"
Support is excellent. They support cross-shipping on their RMAs and have Step-up.
ASUS makes a ton of X58 boards, to include the ROG series and the aferementioned Sabertooth, but their American support may be very flaky at times.
For price and features and pretty good support you have to take a look at what Gigabyte has to offer.
Their boards are generally solid and overclock very well.
If you dont want X58 per se I'd look hard at an EVGA P55 FTW board. You can get pretty close to X58 performance with a S1156 Hyperthreaded CPU, and those boards overclock very well.
Me and my cousin built a system with GIGABYTE GA-X58A-UD3R and he couldn't be happier with his setup. Since Sandy cpu is around the corner I would think that Intel motherboards will go down in price.
I've been on an Asus p7h55-m with an i7 and it's been flawless.
Historically I've usually gone with MSI or Asus, I've never had problems with either. ECS on the other hand...
Judging by the processor he mentioned (i7 970) and the motherboard he mentioned DX58SO I'd guess he's getting the processor from the IREP, so he's getting that 6 core processor for around $200-250. The only downside is that processor absolutely requires a 1366 motherboard and those motherboards tend to be sizable more expensive than 1156 motherboards.
The EVGA motherboards will be great OC'ers, although they really shine with LN2. Asus seems to be a bit better with Air cooling and Water cooling. So I would say go with EVGA since their support is amazing, whereas I have only heard bad about Asus(difficult, but ASUS products don't seem to break very much).
If aesthetics don't matter to you, here's a supermicro board that actually has onboard audio. http://www.newegg.com/Product/Product.aspx?Item=N82E16813182165 Can't go wrong with server quality and intel integrated lan ports.
Seems a kind of weird board. On the one hand dual PCIe x16 and lack of onboard graphics/lights out management screams desktop rather than server. On the other hand it's marketed as a server board and those PCI-X slots are likely to be of limited usefulness for a desktop.
