What monitors are these?
ynih
Quick, if you can guess I will give you a dollar. :p
I was watching Casino royale and saw the M16 kids had some nice dual screen 20 inchers. (at least I think they are by the size of the webpage and the font)
Seeeing as how the movie is completely Sony dominated, I'm going to venture a guess that they are 20" Sony ones? LOL. maybe they are NEC, but I can't really tell.
Anyone else got a clue, or guesses? or model numbers?
anybody? anybody dare venture a guess? I'm really curious...they look like they are a pair of nice 20 inchers...
hard to tell from the picture, the shape, position of the usb port, and placement of the shiny stripe (logo) in the middle reminds me of the philips 200P7EB. are there more pictures?
probably not the philips.. I forgot it has a rounded back side..
I can't remenmer a 20'' sony with a bottom frame of this size, but it could be a 19 inch model like the SDM-X95K.
lol, yes, yes it's definitely the westy.
They had another photograph of the backside top trim (it isn't much) and a shot of the screen. It doesn't look like a 19 incher. The dotpitch looked pretty small to me. I don't have the DVD anymore (returned it) so I can't take a picture of the screen.
Somehow I doubt it's the Phillips, since every other product or gadget is subliminally branded a Sony.
yes it's not the philips, (as stated the back side of the bezel doesn't match) The frame design looks like a sony but the lower part only matches 19 inch models I know of.
After scaling a 20'' resolution down to the size of the screencapture, I noticed that the original start button is bigger than it would be on a 1600* res. (any PC resolution will look tiny seen on a TV screen)
I'm 90% sure its the SDM-X95K or similar model.
Ahh, okay. nice. very sweet. i think they might be the 19 inchers then.
