What mobo to use?? Need advice
StorageJoe
I am looking for a new motherboard. I would like socket 475 so I can use my same processor (p4 3.0 800MHz FSB). I need at least one pci-x 66MHz slot to run my raid card. AGP would be nice to run my current vid card, but PCI-E would be fine too i guess. Also need a couple pci slots (sound card, tv tuner card, gigabit ethernet). Having a hard time finding a decent board that isn't $400. Any suggestions??
Only one I know of is the Supermicro P4SCT or P4SCT+II
My only question is if it is worth the money for that old of a CPU.. (not that it is too slow, but rather that dual core CPU's are available now)
==>Lazn
I guess I'm fine w/ replacing the cpu. All it really NEED is a pci-x (64-bit 66MHz) and somewhere to plug a video card (either pci-e or agp) as well as a couple pci ports (i'd like at least 3). Are there any other options??
Do you want to stick with Intel, or would you think of AMD.. and how much money are you thinking of spending total?
The cheapest would be to just get one of those supermicros at ~$220-$250
Do you really NEED PCI-X? most RAID cards will work in a 32bit slot.. true that limits the total bandwidth down to 133MB/s but most RAID arrays will not push that for long anyways.
==>Lazn
I don't really need pci-x, but it was the reason I was looking at a new board in the first place. My LSI rep game me a "demo" megaraid 150-6 raid card and I would hate to go buy 6 sata drives and think I was screwing myself out of bandwidth.
Are you going to use RAID 5?
If so, the LSI 150 - 4 with 4 drives gets about 60mb/s reads and 8 MB/s writes in RAID 5.
(yet that is 8 MB/s, even lower with some benchmarks)
The extra two drives will probably not change this a whole lot.
http://www6.tomshardware.com/storage/20040625/sata-raid-11.html#benchmarks
RAID 5 writes blow chunks.. and 4 drives will not even half way saturate a standard PCI slot in RAID 5, I would be suprized if 6 drives did.
If you are going to use RAID 0 (not recommended due to data loss likelyhood with that many drives) you might start to care about PCI-X..
==>Lazn
