What mobo to buy?
rusty
im thinking of upgrading, and was wondering which mobo i should invest in. i got my brother a nf7-s with some corsair and a 3500 barton and that runs great, so i was thinking of either getting his setup, but i know that amd64 is out, and was wondering if i should get that. any ideas? thanks
If you're going the AMD route, get either the Abit NF7-S or ASUS A7N8X Deluxe. Both boards I've used, and recommend highly. :)
Edit: But the Abit is cheaper (Newegg).
I'd recommend both of these boards as well. I'd also say go with an AMD64 setup if you have the $$, although I don't know what boards are quality for 64bit procs. If you are at all thinking intel I'd say go with ABIT IC7-max3 and a 2.8c or 3.2c.
