What memory to get for e6400 / e6600 @ 3.5ghz
Z
Zinn
Guest
I'm thinking about selling all of my personal posessions to get either an e6600 or e6400 and the Gigabyte GA-965P-DS3 board. Either way I want to run at or near 3.5 ghz.
What would be the best memory and the best course of action to achieve this? I assume it would be easier to hit 3.5ghz with cheaper memory on the e6600 because of the higher multiplier. The e6600 costs almost $100 more than the e6400, so if there is any memory that lets me achieve this overclock and is less than $100 more than whatever memory I would use with the e6600, then the e6400 would be a better buy. The cache size isn't a huge consideration to me.
So what should I do? My goal is to minimize costs, but still achieve a respectable overclock. I really don't know much about DDR2 memory at the moment either as I'm still on 939. Please share your thoughts with me. :)
The Corsair XMS stuff, or most OCZ platinum or special anniversary edition...
Any of those are pretty much guarenteed to hit the 850 range. Christ, most hit the 1000 range...
