pirateface
- May 21, 2002
4 months ago or so, my fan on my Hercules 9800pro HSF started to stick, as it was spinning slower and was making a bit of a noise. The Fan isn't gunked in dust or anything I clean my case every month or two. The Fan is basically lubeless.
I've since then have put a few drops of DW40 and tape'ed up the seal and it has been working fine, but it seems to only be a temporary solution as I've lubed it up just now for the 3rd time in the last 4 months.
I was wondering what kind of lube I should be using for a longer run, such as a greese or something.
