What limits i7 BLCK?
Kardonxt
I was trying to push my I7 a little farther last night and ran into a wall at a blck of 205.
It doesn't make any sense to me. The cpu temps were fine, voltage was pretty low. F@H -bigadv unit stable. It runs like a champ at 205.
Bumping the blck to 206 or anything just causes the system to not Post. I've tried upping voltages, changing qpi link, lowering the multi from 21 to 20 to 19, Updated BIOS. Nothing.
I will admit I'm still behind when it comes to i7 overclocking. But if this was one of my 775 builds and I was getting close to my max oc it would start to act unstable long before refusing to boot from a 1mhz fsb increase.
What seems to limit blck? Temps? Do i need a new mobo? Is it the cpu? Maybe I'm missing a setting?
I'm pretty happy with 4.3ghz. It just seems strange to me that it would just fall flat on its face @ 206. I was going to build a nice WC loop but if temps are not the problem then I guess there's no point
Might be your motherboard. Did you try a high bclk and really low multiplier so that you're running below 4ghz? My D0 requires more voltage than yours to get to 4ghz (1.3v), but my chip will handle 211bclk fine on my Asus P6T6 WS.
Also, what's your uncore voltage? I need 1.7v on mine to run 2000mhz modules.
i have not tried anything bellow 19. I'll give that a shot when I get home
I don't even know what voltage uncore is at anymore after messing with everything so much last night. I will let you know as soon as I get home from work. I do know that I've been running my 2000 at 1600 just to make sure i don't run into ram issues.
Thanks for the reply :)
