what lcd wipes do you guys use?
m0nty
i google some up and there like 20 different versions... which one do you guys prefer? i have a 2005fpw btw :|
Yes, paper towels can damage the screen as they are (believe it or not) relatively abrasive in comparison to a soft cloth. I use a CRT rather than an LCD, but personally I use clean t-shirts.
I used the little chamois thing that came with my screen and the special cleaning towelettes then I realized plain old water on a soft cotton (has to be cotton) towel works best.
I use filtered water and the softcloth that came with my scanner.
so a cotton t-shirt and just damp it? wipe it across the screen a few times and let it self dry and use the dry side to get the wet spots off?
That'll do the trick.
Apple ehh? That's a nice touch of them to do that isn't it? Everyone of their LCD using computers/monitors comes with one.
I use fellowes NO alcohol no static..good with disposable...
i don't want any foreign objects scratchign the screen with a resued cloth.
Get yourself a "Microfiber" cloth, a good one wont scratch no matter how much you buff. You can find them at any hardware or auto-care store. Mine is made by some company called "Meguiars" it works great.
As for cleaning solutions, i just use distilled water. :D
yeah ... i was once told "if you wouldn't use it to wipe your butt, don't use it to clean your car" ... meaning if it's too rough to wipe your butt, it'll probably damage the finish of your car a little bit (would u use a paper towel back there?? ;))
I'm assuming the same thing goes for LCD's. Get a microfiber cloth. They have them at any autoparts store. go ahead and get one for your car too, they do wonders for cleaning it :)
Actually it came with my Dell 700m.
You can get them HERE for under $5.
The cloth i have is a 16x16 in. towel is washable and can be reused over and over.
5.95 shipping for me :(
I picked up some over priced "Monster Cable Screen Cleen" and OMFG just try it and you will be hooked!
I also use a microfiber cloth and I have a LCD and 3 CRT's and 2 plasma TV's.
cotton is very abrasive so wouldnt suggest using that... I personally use a cloth diaper on my screen and no problems
I use a microfiber cloth myself. Doctor gave me one for use on my glasses a long time ago, and never got a single scratch, so I figured, what's good for optics must be good for an LCD too, right? Yep, works great. I tend to loose them before needing to wash them, but they can be washed as well.
though this has been beat to death...another vote for microfiber...I use it on my ibook to clean the screen all the time
i use a microfiber cloth used for primairly guitar polishing, (microfibers are much more gentil than a everyday, normal cloth weve) microfiber cloths are lint free, and have never scratched my PRS custom 24 /w platnum dragon pickups ($6000 guitar)
I use a microfiber cloth bought at wal-mart for $5. It's a 3m microfiber dusting cloth... was in the aisle with kitchen cleaning stuff.
OT but if you paid $6k for that guitar, you got ripped horribly. A mint 10-top is worth about $1900-2000, and a mint pre-94 10-top is worth about $2500.
If you won't even polish it with cloth, what do you do when you play it? Do you don a microfiber jumpsuit? I know of some fanatics who wear a goofy looking flannel suit for when they play their vintage collection, but never for just a production model PRS.
Cloth diaper...clean or used?
Hey, maybe the stuff in the used diaper works as a good lubricant or polish?
:D
Okay, to be on topic, I posted a thread on this but only got one reply (but thanks for the one I did get. ;) ), but anyway, how about getting a scratch out of a LCD? It's not bad, but it is noteable when the screen is black, or when the color is really vibrant and bright? Coffee33 also suggested the Monster Cable brand of stuff, but any other suggestions before I buy some gunk and give it a go?
Me <---Admits that half the reason I'm adding an on topic bit is so my diaper comment will stay. ;)
This man speaks the truth. I use it on my plasma as well as all of the LCD, CRT, DLP, LCoS, and other types of monitors where I work. It is absolutely the best you can get. Pricey at $19 but worth it.
obviously u dont play guitar kremlin or u do and u dont know much, all guitar polishing cloths are microfiber for 1 thing, and my prs guitar is a custom 24 body,not a standard 24 or their production custom 24 series, but actualy from PRS' custom shop (custom material, neck, inlays, pickups, floyd rose locking trem, the dragon pickups are the active version which are only used on the dragon I, II, and III. the paintjob is a custom mix of ebony/dark metalic red, and airbrushed with a skull left of the trem. trust me my guitar is woth $6000 ill be glad to post a pic when i get my digital camera back from my sister.
and yes its not a knock off pos model that u would buy at guitar center, this is from PRS's custom shop directly.
pre 94's mint are worth in the $3000-4000 range depending on ware and tear
I bought the same thing for my LCD TV. Works great as it comes with a spray bottle of cleaning solution and a pretty big cleaning cloth. At work I got a set of microfibre cloths and a Kensington LCD cleaner. I think Staples sells it for pretty cheap--it works creat for cleaning laptops!
