-=Antimatter=-
- Feb 8, 2005
Looking to do a little scripting; I need to write two or three scripts that can do the following tasks:
1. Parse through an xml file, obtain a list of names, and create a copy of a folder full of files for each name with the name appended to the folder name.
2. Ask a user for a word, then parse through an xml file and replace a word with the given word.
3. Copy files from multiple instances of a known folder structure to another folder.
Perl? Python? Ideally I'd like something that would be simple to execute like a compiled executable, and would work on both Windows and Unix systems.
Thanks in advance
Thanks in advance
