What kinda system needs 1kW+ PSU?
soulesschild
What kinda system would need a 1kW+ PSU? I'm still on the fence about getting the BFG ES-800 vs Corsair 1000HX or waiting for the enermax revolution 85+....but just exactly what kinda system would need a 1000w+ PSU?
Dual 4870X2s with an array of 4 HDDs, a couple optical hard drives, a heavily overclocked quad core CPU, with enough fans to turn the PC into a hover craft. This might approach the 900Watt range.
mine under dual 4870x2 | 4 SAS drive | quad cpu | SAS card | 6 fan | 2 DVD
pull around 900-1000 under load from the wall
Holy crap Pao....thsoe 4870x2s are monsters :O Are they OCed?
I don't think I'd ever go CF 4870x2s..can't justify the price :[
it was factory oc'ed to 800mhz ^^
Yea haha I did a rough estimate using the extremevision PSu calculator running something ridcioulous like a 4.2Ghz Quad, 8GB mem, 6 HDDs, 2x 4870x2's OCED to 800/3600, 8 120mm fans, 2x 230fans, sound blaster card, water cooling, and it came to like 937 at 90% load. Taking out one of the 4870x2's dropped it to like 697W.
that's almost identical to mine system but mine running on 4ghz not 4.2 ^^
Having it running the fridge, stove, microwave and outisde BBQ lol
Basically its for the multi GPU systems. Atleast when you go by the manufacturer. This is just one example. Pick any setup and look at the certified wattage needed.
http://www.slizone.com/object/slizone_build_psu.html
how can you tell your current power usage?
All my stuff is plugged into the APC.
:D main rig in my sig.
