There's this point, where the card is in stock, but someone else has it in their cart so they can't sell it...
The simple answer is there are 10000 other people doing the exact same thing you are right now. If someone gets it in their cart, then purchases the last one before you, the item will show as not in stock. No BS or smoke and mirrors here, and it's fair IMO.
NewEgg doesn't "hold" items if you put them in your cart -- why would they? If you went to brick and mortor store, would you expect them to not sell an item to someone else just because you pointed at it?
its more like someone comes and takes it out of your basket before you finish shopping.
The site still tells customers an item is in stock, and allows them to add to their cart, only to remove it when checking out. That is obviously the wrong way to do it. It's frustrating as hell.
Seriously? I need to spell this out?What would you suggest then?
They know when an item is in stock. It's computerized, they aren't using carbon copies like 1957. When an item isn't in stock, the website should say "out of stock".
A Firefox derivative browser is your problem there.
