What kind of memory does G92 GTS use?
blade52x
So today I've started to see how high my memory on the GTS will go... so far I'm at 2100MHz stable. I've seen other's report as high as 2200MHz. Now, from that I remember on my GT, the highest I could get before it went berserk on me was about 2060MHz. And then there was the possible issue of the memory burning out if being ran at a constant 2000MHz, so many didn't overclock their memory.
But the G92 GTS seems to have better clocking memory. I assume either the stock voltage is higher on the same memory as the G92 GT uses, or do they use different memory? I'm also aware that looser memory timings could account for higher clocks.
I already did a search on google, but seem to be having trouble finding the info as all I keep running into is GT info, so if anyone knows, please let me know!
