That's correct, Intel introduced rd-ram with the socket P3s but it failed big time due to it being insanely costly at the time and the p3 not needing that of bw. Not to mention the problems with delivering rd-ram enough and some chipset issues.Originally posted by merlin704
If you can find a motherboard with the i820 chipset, I believe, it will use RDRAM.
Originally posted by p0b0y
i believe the i820 chipset was for rdram, the issue was with the memory hub not liking sdram
i had a vc820 mb/2x128mb pc800 rdram/p3 833, it was the bomb back in the day
Originally posted by jeef
luckily the 866EB is a socket 370 coppermine...
it looks like the 815 chipset is where it really shines, but just so you know it only supports 512MB max memory. should be enough for a p3 tho.
To bad they never fixed that. The i820 chipset would have had a longer life span.
Originally posted by TheAcorn
Bingo, Macklin! that was the name of it.
I personally wouldn't trade my Apollo Pro 133 @ 150mhz for it, either. If I have to invest in DDR, I'm investing in an AXP and a SocketA... And RDRAM was always a joke, anyways.
Good luck on finding DECENT SDRAM for that P3, btw, there isn't a lot of it out there these days - mostly el-cheapo CAS3 garbage. And as far as finding low-density PC133.... forget that, too. The P3 was and still is one of the most expensive system setups ever - Look at the going rate of Tualatin P3s, still.
