What is WZCSLDR?
skym0903
Hi I have a question about a automatic start up on one program
I have no idea what it does or what it is. And it makes my cpu work at 50% when it's at idle. I don't like my cpu getting hot when it's at idle. It was at 50 C and when I end the program in the task manager the temperature goes back down.
So I went to msconfig and checked where the program was located it was at C:\Program Files\Alpha Networks\ANIWZCS Service
The program that was running was WZCSLDR
I search the internet and looked for it but it lead me to here since some other posts had the same WZCSLDR program on their log.
Thanks for the information in advance~
I found the same links you found on the net with the same results. You could just disable it from startup in MSCONFIG and see if something doesn't work. If nothing screwed up, you didn't need it so no harm done. :)
