Jakalwarrior
- Aug 6, 2005
Let me start by saying this is as 1280x1024 with a 2900pro @ 800/900.......
I think he wants to know why he is only getting 26.3 FPS I get better than that on a 7600gs, p4 3.06.
No wonder, his 2900Pro is in a UPS truck.(update your sig). Sounds like a possible driver issue, what level AA are you using? Sometimes overclocking too high won't produce artifacts but will cause lower performance. Try stock clocks and see what the results are.
You use too many mouse clicks and not enough key bindings?
That card would likely do better supported by a Q6600 G-0 @ 3.0GHz or higher. The cards ATi have recently been releasing are also much stronger in SM 3.0 than 2.0. 1280x is not often a GPU limited res. I am guessing CPU and possibly WoW uses a lot of SM 2.0 or lower.
Wow doesn't use a lot of anything... you should be able to pwn that game. I'd suggest running a driver cleaner, and reloading them.
Actually since the last patch (or maybe two patches?) WoW uses a ton of cpu. They optimized it for multiple cores and since they did that I have seen wow take 90% of both of my cores.
Ok... I haven't played in about 4-5 months. However back when I played, it would play fine on a 1.6 Ghz Duron. I'm pretty sure that no matter how much they changed, you still don't need a 3.0 ghz q6600 to play it, which is what backlash was suggesting.
