Airjarhead
- Mar 11, 2007
Hey guys,
I got a Q6600 from Fry's on BF and replaced my E4300. Since I really don't have a lot of time to mess with it, I just figured I'd go for a modest overclock of 3GHz. However, I can't get it to to through more than an hour of Prime 95 for more than an hour without one of the cores failing. Also, I find it a little weird that the temp difference between the 1st core and the 4th core is 6-7 degrees C. This is what I've tried:
-I tried going to 400x8 and Vcore of 1.35 and it wouldn't boot!
-I tried 350x9 and got blue screens before an hour was up.
-Stock volts at 333x9 (Mem at 1:1) and core 0 failed just before an hour, the rest went 6 hours without error (I had left it over night).
-I upped the Vcore to 1.3125 and core 2 failed after an hour.
-I upped the volts to 1.35 and core 1 failed at 40 mins.
I'm using Everest for Temps (because of the coretemp issue with Vista x64), and none of the cores go over 60 degrees.
I've run memtest all night a few times at different settings and have never had any errors.
What do you think it is?
Thanks,
Thanks,
