What is wrong with my CPU?
Clementi
This CPU I have is so weird. I don't know why, but it will not stop fluctuating when it is idle. It's an AMD Atholon 64 4000+ socket 939.
Here is a pic of it running idle. I have some processes other than the system's running but I tried closing them and it didn't make a difference.
I'm going to bed. I'll check this tomorrow after school.
Did you check the "processes" tab to see which process is using up all those cpu cycles?
Doesn't seem idle to me. Strange though. I'd click on the processes tab and check what's using the cpu.
WLservice.exe monitors your wireless lan. I'd uninstall or remove any Wlan cards and see if it goes away.
looks like your wireless adapter... I would update the drivers for your wireless adapter.
nicely done guys, thanks. I was the adapter.
I'll figure it out later. I'm really going to sleep now, I've got to get up in less than 5 hours.
