jamezzz122
- Jun 1, 2003
Well when I try to connect in Kazaa Lite K++, it says it is connecting but is there froever. And in WinMX I can only make a secondary connection. When I try to switch it to primary, it says IO can't before I have no TCP port for incoming connections and No UDP port for incoming and outgoing packets. I should also mention that this computer is wireless. Should I do some port fowarding? If so, what ports? I used to have troubles with my Bit Torrent but fowarding ports fixed them.
