what is USB4 good for?
So the new am5 motherboards are supposed to have USB4 and most manufacturers are dedicating four pcie lanes for these things.
What I'm trying to figure out is....what are they good for? I see where you can do an egpu, which is cool and all, but if I'm getting a motherboard, it already has a full blown pcie slot.
What am I missing? Am I the only one that wishes those lanes went to another slot/m.2?
The one really nice thing about USB4 is built-in Thunderbolt compatibility. Thunderbolt 4 is part of the USB4 spec. Other high-speed ports like USB 3.2 are already pretty fast but Thunderbolt opens up more possibilities. Even if you aren't using it now, it's definitely one of those things that might come in handy in the future if you keep your system for a while.
You could get an "older" X670E board if you wanted. The actual chipsets that it uses are the same as the X870E, but X670E lacks USB4 (on most boards).
On all of the boards that I've looked at, the lanes are already shared with a M.2 or something else.
There simply aren't enough pcie lanes on any non-pro chipsets, unless we're talking about a really small form factor that doesn't have the space for multiple pcie slots and M.2's.
On some boards (mostly X870E) you can control it through the bios, but not on others (X670E).
When I bought a new board last year, I went with the MSI MEG X670E ACE over all of the X870E boards precisely because it didn't lane share with the M.2 slots or the bottom PCIE slot.
USB4 thunderbolt would be cool, but I don't have a use for it at the moment. Perhaps with Zen 7, or if Intel gets off their ass, I'll find a use for it with a future upgrade. I tried using the onboard USB C 3.2 DP as an audio output source, yet never got Dolby Atmos working. I tried many different cables, even the best working ones would cut out 50% of the output, so perhaps USB4 would be that use case as this board doesn't have a standard HDMI or DP output for audio to a receiver.
I've got all four M.2 slots occupied, my GPU running at 5.0 x16, and a RAID card in the bottom slot running 3.0 x4 (it's an x8 card, but x4 is the minimum that will work). Picked it up on sale for $370.
Edit: you could run an external M.2 docking bay with USB4 thunderbolt. Or even better, a U.2 or U.3 dock with a large enterprise drive - easier than finding an M.2 adapter and cable that will work properly with newer U.3 drives.
PCIe tunneling make for quick connection of PCIe (GPU, nvmes....) easy, fancy video out (2x4k monitor), super fast pc-to-pc transfer with a single cable, fancy docking station to do all of this easily, more useful for temporary stuff (Laptop that move around) than desktop.
Those could be useful in the future feature on motherboard... in my experience for me rarely get used (if I was not already using them and easy to use more like m.2 slots), specially if it could have been done with a pci card if need to anyway, were not worth it.
whats usb4 for? connecting fast things or gpus.
i dont need more lanes.
USB4, Thunderbolt, etc. are great for laptops. I have a Thunderbolt 4 dock for my work laptop. One cable, runs a couple screens up to 4k, charges the laptop, connects ethernet, USB, etc. That's what Thunderbolt is good for. On a desktop? I dunno, haven't found a use for it yet. One fast port is nice for plugging in an external storage device and doing backups I guess, but then you have to pay for a USB4/Thunderbolt backup device. Yeah no I'll just use the USB-C stuff... or not. I mostly do cloud backups except for a small amount of sensitive stuff I don't want in the cloud. What's left is small enough that I don't need speed. USB key or burn a DVD is fast and big enough.
For laptops or mini-PC's, USB 4.0 is decent for an eGPU (Oculink is faster, but you have to start Oculink before you turn the system on). It's also good for docking stations if you're not gaming, so you don't have to deal with plugging and unplugging all your cables.
For desktops, I take a lot of photos and videos, so having a USB 4.0 (40Gbps) for file transfer is way, way faster than using USB 3.0 (5Gbps), or even USB 3.2 Gen 2x2 (20Gbps, but only 10Gbps per lane).
It's pretty niche, but it's nicer to have it, than to not have it.
i was re-reading the manual for the msi x870e tomahawk last night and they did it right...
The have the usb4, but you can shut it totally off and use those four lanes on another m.2.
Now I remember why I liked that one.
