What Is up with this crap!
Jzegers24
Ok, got a new mobo/cpu today. I put everything in, hit the power button, it turns on for like 1 second than shuts off. I switch psu's, same beef. I put it in my main rig, works like a charm? WTF is up? Could it be a bad ground? Something is royaly fucked up. Any ideas?
did you use a thermal pad or arctic silver?
sounds like it is over heating to me, reseat the cpu and heatsink, then reset cmos, and try again
Check the position of the CMOS reset jumper, some boards ship with te jumper in the RESET position from the factory after QC inspection.
Later
MD
yeah, swapped everything out of the case and into my case, bam works perfect, put it all abck in the other one, no go? that is really weird..........
check for the position of the bolts, you may be having a false contact there and can screw up your mobo
i know cause it happened to me once....
most likely something is shorted to ground (i.e. one of your hot rails). The power supply's overvoltage protection is probably kicking in. Sometimes ribbon IDE cables get stripped and touch the case.. sometimes a standoff is missing and will touch. There are a few variables to eliminate. I'd be wary of any thin cables such as IDE cables or fan cables..
Chickenmon said:
All your base are belong to us
Off topic
Us still have your brain on order.
On topic
I also think its a bad ground, but maybe its the power button thats sticky/faulty.
My other rig (cheap case) has a plastic button that just presses the "Real" powerbutton
I have had times before when the powerbutton (real 1) just became stuck in the "On" position thus shutting off after 3-4 seconds, while the plastic button was in the OFF position, because
a little spring behind it forces it back.
I know you wrote "Like 1 second" but maybe its worth a try.
LOL I knew some smart ass would bring that back.
Back on topic sounds like you just had a bad connection somewhere.
