what is this power connecter?
RADEoN
up top/right it says ATX12V1... all my motherboard currently has is a 4 pin... what's up with this? is there something i'm missing?
i know you can still use the 4 pin im not sure what side you can put it on but i know it's says in the manual.
thats the 8pin 12v power connector.
You may be more familiar with the 4 pin 12v introduced on the p4 socket 478 boards. same thing. more juice.
*edit*
it is a row of 12v and a row of grounds so it will be ok.
It's the new ATX standard AUX power connection; been around for about 2 years now. Longer in the server market.
shit, so i won't be able to use my 4-pin? or is brysig right?
it should only fit in one place with the tab in the right dirrection, check your documentation and see if theres a warning about using only 4pin
You can use the 4 pin, but some boards prove move stable with the 8 pin used. I believe you can buy an adapter.
If you're building a high end machine and your PSU is old enough to have a 4 pin ATX connection... you might need to consider replacing it anyway.
yeah i agree. it's not a real old powersupply, antec truepower 430 2.0... you got anything to sell?
silent is correct on both accounts. I've used an adapter to go from 4-8 on a previous build, 300w psu for a quad even :D
Oh my god man. Those things explode and kill babies.
I'm only exaggerating slightly.
Had 2 original TruePower 500 watts and 1 Truepower 2.0 550 watt die powering a basic single core Athlon 64 machine. They're horrible. Recycle that hunk of trash before it kills your shiny new machine.
Also, no, nothing to sell at the moment.
heh i've been usin antec for years. i have an original truepower from 4-5 years ago still supplying power.
but will it work for a few days while i decide on which power supply to obtain, or do i NEED that adapter?
For a few days, yeah, but I wouldn't trust it any longer than absolutely necessary. Also, avoid Antec. Seriously. Corsair, Seasonic, Silverstone, PC Power & Cooling... so many better options. Antec PSUs are trash, with only a few exceptions.
this is what the manual says for the ip35 pro "you may connect either 4-pin atx12v or an 8pin eps12v power source.However, it is recommended to connect the 8-pin eps12v power source to meet the 240va protection limits."
its all up to you if you want to use the 4-pin. i think it's should be ok to use..
i'll probably get a corsair nothing but luck with their RAM.. any recommendations for this system for a PSU?
AW9D-MAX
Q6600
4 GB DDR2-800
Radeon HD3870 (1 for now, 2 in may)
2 DVD burners
3 Hard drives,
4 120mm fans
1 200mm fan
all stuffed into an antec 900 case
thats not true. Antec spans top the bottem, with antec PSUs, you get what you pay for.
thanks bro. do you see which side to connect it on?
ah, i used to know so much about this stuff, then i got out of the loop.
here's something to fill you in, the last time i bought brand new parts was mid 2004. ic7-max3, p4 3.0e 2gb ddr400 and x800xt-pe.. couldn't be beat lol.
That was true of me until not long ago. I just beat you to the rebuild by ~8 months. Took the Athlon route before, though. Intel this time.
heh nice. can you recommend a good power supply for ~100 bucks from what i said i will be running?
The 620HX or 750TX would be ideal. The 550VX can take it, but isn't ideal. The 750TX is on sale at Buy.com for $115 AR right now. That'd last you... for the forseeable future.
thanks for finding me those links, i really appreciate all the help guys. i'm gonna use my 430 for probably about a week, and during this week i'm gonna check out deals and maybe someone will list a good one used on here by next week, if not i'll buy new i guess.
thanks again.
