what is the stock e6600 voltage?
Dutt1113
I was just wondering what the stock voltage on the e6600 is. I went into bios and it says auto or something.
download cpu-z and see what it reads it at but from memory I believe its 1.248.
I downloaded cpu-z. So far I have my e6600 overclocked to 2.8ghz with the cpu voltage set at the default auto. cpu-z is reading from 1.16v - 1.176v. Does that sound about right? If I had to set the cpu voltage to its default value manually, what would I set it at?
Are you using the 7x multiplier? Lower multipliers run at lower voltages, so that sounds right.
I'm using the stock 9x multiplier.
