RJ1892
- Apr 3, 2014
I have some plasticizer in my loop, mainly sitting in the reservoir and some in the GPU block and probably the CPU block. I want to flush it as best as I can without tearing the entire system apart (I plan to tear it all apart sometime when a Volta Titan comes out). But would like to just flush the system for now.
Should I just run distilled water through it for a few hours, then drain it, then run a new batch of distilled water, a few times over? I assembled my cooling loop in September and just want to make sure plasticizer deposits don't end up effecting cooling performance by clogging up the loop, as of now it has not affected performance.
