What is the longest E-SATA extension cable ?
mnmgri4
I am thinking of leaving my case in the basement and putting my keyboard, mouse and monitor on the first floor of my home. I would like to put an external sata dvd/rw on the desk also. In order to do so I would need about a 16' long e-sata cable.
Do they make one this long or can I daisy chain shorter ones together ? The longest I have found is 6.5'.:( Is this distance not do-able with e-sata ?
Should I go with an external enclosure with usb2.0 /firewire support and a IDE dvd/rw instead ? Or go with sata dvd/rw with a usb2.0 enclosure ?
Any suggestions ???
Max cable lengths:
eSata - 2m/6.5ft, not daisy chain capable
USB 2.0 - 5m/16.4ft, can connect max of 6 cables using powered hubs to extend range to 30m/98.5ft
Firewire 400/800 - 4.5m/14.8ft, can use max of 16 cables using powered hubs to extend range to 72m/236ft
Firewire 800(with optical connect) - 100m/328ft, optical adaptors are $$$
Thanks for clearing that up. Would I be better off going with USB or FIREWIRE then ?
