The first is the older IDE standard and is a slower version at that.
The second is SATA and is the newer faster SATA spec.
I agree.I wouldnt buy an IDE drive now.
While the SATA spec does provide for a higher transfer rate, it does not affect performance much. If you car cannot drive faster than 50mph, it does not matter whether the speed limit if 65 or 95.
a 3GB/s controller will be able to sustain higher data transfers from a larger RAID array.
