What is the difference between start voltage and voltage?
Ristogod
I am planning on OC'ing my CPU. I suspect I may have to raise voltages in doing so.
In the BIOS there are multiple voltage settings for the CPU. One sets the voltage by increasing by a certain percentage. But there are two other settings. One is startup voltage, and the other is just voltage. What is the difference between the two? Should I be increasing both as when trying to overclock? I don't quite understand the purpose of this?
My old K8N Neo 2 also had these settings, but I never overclocked on that board, so I never learned what the difference between the two were.
Someone correct me if I'm wrong.. But 'Start' Voltage is just that, the starting voltage that is used to boot up the motherboard.. the one that is just 'voltage' is the volts going into the CPU after initial startup (Kinda like kinetic and Static forces in physics.. though.. of course, considering electicity priciples are something learned in basic phsyics..)
On a side note.. if your asking about voltages.. maybe you should read up a bit more before you attempt playing with them? (not being rude.. just dont want you messing up something because you dont know what your doing.. motherboards and processors are not cheap to replace.)
when you boot up your rig it takes a big power hit to spin up the hard drives and start everything up at once. once it is running everything will stable out and your voltages should remain pretty constant.
just a side note, your signature is 6 lines too long (max length is 10 lines @ 800x600)
No, I'm actually an accomplished overclocker. I used to have a watercooled XP Mobile running
at 2.6GHz on watercooling.
It's just that in the past, the motherboards I had used had no such feature as startup voltage. Quite often you will find that they label such settings in the BIOS that make very little sense. So even though I thought that it was simply the voltage to used when powering up, I wanted to verify that with someone else.
The past year I had a MSI K8N Neo 2 motherboard. Well, that board just did not want to overclock to my expectations. So I simply didn't overclock. I left everything at stock speeds. Well, now that I have this much newer nicer motherboard, I wanted to get back into the overclocking arena. So when I saw this setting, I only wanted to verify my curiosities.
Well, being that it is only the voltage used for starting up, I'm assuming it plays no role in effectiveness of overclocking. Some one correct me though if they've experienced otherwise.
Ahh.. I just wanted to be sure. Anyway, no.. the startup voltage will not have any affect on overclocking, as it is only to get the system running.
