What is the difference between Doom 3 High/Ultra
Jerry1978
i've taken dozens of screens so far in exactly the same positions to compare the lighting and texture resolution and i can't find a single difference on my 6800 GT. i think textures are uncompressed in high quality anyway, so the only thing that should (or could) change is the lighting.
can someone post a couple of screenshots that they have taken in exactly the same position with high and ultra quality and then circle the area on the picture that is different? :confused:
thanks.
The differences are specular level and lighting detail. Very bleak differences. Ultra is only good if you have 512mb of video memory, then you will see a huge performance increase, since it runs everything uncompressed.
