Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Which is the preferred one to run in ./fah6 -configonly? Which gives the most ppd? Is this just two different phases of the same project? Best regards, Charlie
bigadv- "Stable" units, they have been tested, and are a *known* quantity
bigbeta- "Unstable" units, not tested [hence beta], can crash, and if you are not on the beta team you get zero support on them, and are widely varied in points
Thanks, W.Feather,
Questions:
1. How do you get on the Beta Testing Team? How do you qualify?
2. So is there any way to set up -configonly to accept both types, preferably with a preference?
