What is the deal!?!
luckyou03
ok i just upgraded my system today and it isn't living up to my expectations.
My old setup was this
Pentium D 920 2.8ghz/2mb cache/800 bus
2 GB pc667
ati x1950xt radeon video card
asus p5l-mx motherboard
windows vista basic
I scored a 18,400-18,700 on 3dmark 03
My new setup
Core 2 duo e4620 2.13 ghz/4mb cache/1066 bus
2 gb pc1066
asus P5K SE motherboard
windows vista basic
I just scored a 19,188
So i just spent a few hundred dollars to get about 500 marks higher. This is HORRIBLE
Curious to why you are using a 3+ year old benchmark that has nothing to deal with how today's games perform.
Also when i power on the system there is a message that says "unknown cpu found, you must flash bios to take advantage of all features. press f1 to resume." well there are no updates at this time for the bios...
This is odd to, just saw it.
did you reinstall windows after doing the upgrade? also is your cpu the 6420? not a 4620? if its not a clean install of windows drivers could be messin stuff up bad. Also 3dmark is just that 3d mark you need to do something that doesnt tax your same video card as much as a cpu test
If your CPU isn't being recognized at the BIOS level you're in trouble. That motherboard may not support it, or at least, not support it without a BIOS update, which you said there are none available... Where did you buy it, will they take it back or allow you to exchange, maybe? Also, you may need to reinstall Vista, as it's basically "talking" to the chip improperly if it's showing up as a Pentium D still. You can't just reuse your old OS setup with a new motherboard and CPU. A P5K board should support that CPU though...
Heh, 3D performance is more GPU bound than CPU bound. Your GPU is the same... so I wouldn't expect your score to increase much, especially since you came from a not so bad setup.
You can at least run a repair install of Windows and see if it picks up the change and installs different drivers, but I agree with the above poster that if it's not recognizing it in the BIOS, there's not a lot you can do till a BIOS update is released to add CPU compatibility for your processor.
sorry it's a e6420 core 2 duo processor. I did a fresh install of vista with the hardware upgrade. The motherboard on the box says it supports the core 2 duo and quad core. I opened cpu-z and it's showing this, keep in mine i have ddr2-1066 ram
does intel have CPU drivers like AMD does? maybe its doing that, when i switched out my laptop cpu in vista it didnt change till i went to device manager and uninstalled it
i uninstalled the cpu and restarted and got this
I guess im just going to have to wait for a bios update.
