what is the best socket A mobo?
I am getting a new computer with a XP-M in it, and I am gonna OC it a lot, and I was wondering what the best mobo would be for it, that OC's well, and is stable.
had nothing but good times with my shuttle an35n-ultra
dont think they are too easy to find anymore though. new anyway.
I personally had a great time with my A7N8X Deluxe v1.04, and then my NF7-S rev 2.0.. both were great boards, with a nod to the nf7, but the layout sucked on that board.. my gainward 6800 GT golden sample blocked one of the IDE ports, and the main atx power connector was on the left, which I hate..
Take your chances with the DFI Lanparty NFII series. I have an Ultra B (second one, after I overvolted my RAM on the first- my fault!) First one kicked ass, running a 230FSB. Second one sucks, though, since it can't even take a 210 bus.
ah.. didn't see the OC part of the equation.. the NF7-S is probably the best OC'er you can get.. it has ASSLOADS of community support, and plenty of custom bios's to reach the upper limits of the board.. can't say that much about the other socket a boards..
I really liked my Asus A7N8X Deluxe version 2.0. Was always stable even with my 2800 Barton(hardlocked) at 2.5gigs.
ill hav to say the dfi lanparty because those boards can hit 260fsb and up :) plus it has 3.3v vdimm, 2.0v vcore....good stuff :)
I however, like the nf7-s due to the 2.2v max vcore setting but the vdimm sucks :( gotta get a ocz vdimm booster for that :)
I also tested the shuttle an30r and its pretty decent but hard to get higher fsb.... all three boards were capable of o/cing my 2600+ to 2800mhz on air.
I've got a mobile 2400XP running at 2.63ghz on my water rig. I'm using an epox EP-8RDA3+ But that is more a testament to the MP chips than the motherboard.
Just noticing the tenses that you're using, it seems as though you no long have the 1st lanparty board...am I misreading your post, or did something happen to the first board?
I've got a MSI-KT6V. It is a good board for $50 bucks. I've got my 2600+ overclocked to 2.3GHz. The VCore goes up to 2.3 in the bios and the memory voltage goes up to at least 2.85. I think that I'm held back by my slow memory. It is really DDR333, but I'm running it at DDR400 and it won't go over that stable.
Lyquist
...after I overvolted my RAM on the first- my fault!
I set my RAM to run 3.1V, trying to override a limiter at 2.8V. The limiter blew (killing the CH5- no harm done, I was about to replace it with TCCD), but so did the VRegs on my mobo. It was sent for RMA, and I'm now using its replacement. That's the one that sucks.
DFI Lanparty Nforce2 400 Ultra B
Rock solid.
2400+ XP-M easily at 2400Ghz, didn't want to OC my ram, and runs silky smooth and incredibally stable with lots of OCing headroom.
Another vote for the Asus A7N8X-E Deluxe here... I got a pair of them here with only small OCs... A pair of 2100+ AMDs to 2700+
i think if you want to OC, Abit NF7-S or AN7 or DFI 's lan party series is excellent....
