What is the best Joystick?
MIDO
Hi
What is the best Joystick? from these two Joysticks ??
Logitech Force 3D Pro or Logitech Freedom 2.4 Cordless .
i am planing to get one of them
get this for the game like FSX & BF2 ...etc
Logitech Freedom 2.4 Cordless Joystick
Logitech Force 3D Pro Joystick
always been my favorite... square corners... not circular, which limits what you can do
Hooligan : nice joystick :)
Chaoticon : can i ask you why Force 3D pro ?? :confused:
thanks for your post
CH Flightstick... srsly... consider it.
If u want to go 100% on x axis and 100% on y axis, its one of the very few that will let you do that.
circular joint joy sticks do not
Doesn't Logitech still sell the Extreme3d Pro? Back when I got that, the Force3d was like the budget version of it with no Z-axis twist...
Anyway, why bother spending extra on a cordless joystick when it's pretty much got to sit on a solid, flat surface (i.e. your desk) anyway? I'd say get the Force3d providing it has the twist/Z-axis!
deton8 said my two reasons. The Force 3d isn't wireless, and has z-axis. You may want to consider Hooligans advice, I don't really like either of these logitech joysticks.
I wouldn't get the extreme 3D pro. the calibration on mine is wack, it rolls left. it only lasted about 8 months.
I need to get a joystick too, in anticipation for Jumpgate Evolution. Everybody says that Microsoft used to make the best joysticks, but they stopped a few years ago. Now it seems to be a tossup between Logitech and Saitek. My last one was a Saitek, and I'll probably get another one just to match my keyboard.
