That_Sound_Guy said:O and O defrag.... imo
http://www.whitneyfamily.org/Hacks/?item=Defrag said:My machine at work has a disk full of about 112,000 files and folders taking up about 15GB and it takes less than 8 hours to do a total disk defrag.
djnes said:I know this is purely an opinion issue, but if you take a look at the history between ExecSoftware and O&O, you'll find that one company has always been side by side with Microsoft when developing their products and one has not. One is the over-whelming majority in the corporate world, and one is not allowed on domain machines in certain companies (such as mine) because of high levels of data corruption.
Deadpool9 said:I take it that O&O is the one that corrupts data?
So you being a sample of one is considered a legitimate test? Personal testimonials are great to have, but they need to be taken with a grain of salt, especially compared to industry tests and comparisions. I have yet to see a study, online or in print that placed O&O above Diskeeper. If you know of one, add it to the thread.JL_Audio_User said:Well the corruption must take more than 2 years since I have been using O&O 1 time a week for 2 years.![]()
djnes said:So you being a sample of one is considered a legitimate test? Personal testimonials are great to have, but they need to be taken with a grain of salt, especially compared to industry tests and comparisions. I have yet to see a study, online or in print that placed O&O above Diskeeper. If you know of one, add it to the thread.
As far as personal testimonial, I've had nothing but problems when I tested it under 2000 and XP. Diskeeper is the rock that never fails me, so I'll keep using it.
Ice Czar said:O&O Defrag Pro
Invaluable tool for optimizing, wouldnt want to be without it
I have it intgrated into the MMC and from the commandline as well
running version 4
saturnine2 said:It gives you more options, lets you defrag based on date, filename, etc.
t. shuffle said:I have never understood how either of those options would be valuable.
Complete Name > Using this convention it is possible for you to create directories that will comntain Program Groups closer to the OD (Outer Diameter) of the HDD platter where both the sustained transfer rate and the latency are better, alternately, aps or data that doesnt require a high sustained transfer or that are infrequently accessed can be placed in a directory closer to the ID of the platter (or partition) basically it extends the partition strategy into a single partition, my Adobe and AutoCAD directories being in a much better position than Video Directory (media doesnt require much if its read only)
Complete Date or Access > are primarilly for Database server use, though if you give some thought to it....
say you mount an NTFS Volume as a folder (we'll make it a logical partition\drive in the backend of the HDD in an extended partition) this partition simply holds email files or docs, none of them very big, so even with the lower density in the ID of the disk, the files are also smaller and the latency thus offset, organizing these by date is likely adventageous since your more likely to need to access those than older "storage", thus those files will be closer to the front of the partition, so that when accessed the armeture and head will have less distance to traverse and their position farther out from the ID will have better density and thus lower latency
(caveat, by placing those small and frequently access files as a mounted drive located at the back of the HDD, the arm would need to traverse far outside its "normal" OS partition with considerable ncreased latency, your best access is within any given partition, one of the reasons indexing can have a negative impact on HDD performance, so downloading and writing email as you recieve it by leaving your client open as opposed to checking your email a few times a day can act very similar to indexing, would have little impact for gebneral use, but if your Photoshopin or working on some other disk intensive access, it can be a performance loss)
to understand disk access optimizing its important to understand disks first
Id highly recommend the As the Hard Disc Spins series @ Lost Circuits and Partitioning Strategies @ Radified
That's cause his algorithm evacutates and places. It may move the file anywhere between 1 and n times, but it will be truly defragged when done.S1nF1xx said:Everything was looking pretty good until I read that. Can anyone tell me if it's actually that slow?? It would take an entire day to defrag my machine with all the game files on it.
JL_Audio_User said:***adds djnes to ignore list*** thought he was already there![]()
Ranma_Sao said:That's cause his algorithm evacutates and places. It may move the file anywhere between 1 and n times, but it will be truly defragged when done.
S1nF1xx said:Is there going to be a substantial difference between running that defragmenter and Diskeeper? If there's a big enough boost to be gained I'd say the extra time would be worth it.
RandysWay said:O&O Defrag hands down.
I run PageDfrag v2.32 at the start up to keep the windows kernel running like new I have an 80 gig laptop w/ almost half of it used I run Power Defragmenter GUI 2.0.105 after booting up and it takes only about 5-10 minuets tops to defrag the entire drive on the power defragmentation mode.Ice Czar said:yup
he grabbed the source code form sysinternals
another useful defrag from them is contig
http://www.sysinternals.com/Utilities/Contig.html
which is just for a single file at a time and runs from the commandline
Nothing's wrong with it at all. I've always found it does a good job, it just takes longer than Diskeeper Pro. However, you can basically consider the the built in defragger as Diskeeper Lite. As mentioned above, ExecSoftware wrote the code for it since 2000 I believe.NickN said:I have a question, what's wrong with the included Windows defragger? I only use that one and it seems to work fine, but here it seems that nobody else uses it?![]()
Files are sorted alphabetically from the beginning to the end of the partition. This leads to quick access to files in a directory. When Windows starts up, many system files will be read in sequence from the \WINDOWS and the \WINDOWS\system32 directories (DLLs, system drives, etc.) and the start-up time will therefore be shorter.
KoolDrew said:I prefer O&O too, but moving files to the outer of the drive will do nothing for real-world performance. The same goes for the pagefile (where this is often mentioned). This is because all putting a file on the outer cylinders will do it optimize for sustained transfer rate. Under Windows in real life this would not matter as the head is moving all over the place. What is important is organizing frequently-accessed files so that they are near each other. This optimises seek times which is everything in HD performance.
