Its is to pass along a digital signal to an external DAC/receiver/decoder. If you spent money on a fancy soundcard such as the Xonar, using the S/PDIF out makes your purchase more or less a waste of money. Sounds cards are expensive because of their analog circuity and using S/PDIF bypasses it.
Good place to start, its all explained here: http://www.hardforum.com/showthread.php?t=1410367
5.1 audio if I use the HT setup. Receiver doesn't take 5 3.5mm inputs, and the ALC885 doesn't do 5.1.
You could just use a mini-rca cable if you wanted to use the analog outputs.
What? The ALC885 has 7.1 channel output. All you'd have to do is use a mini-rca for front L/R channels, a mini-rca for center/sub channels, and a mini-rca for rear L/R channels and you'd have analog 5.1. Yeah it's easier to use optical but your receiver/soundcard are not incapable of analog 5.1.Then I still won't have my 5.1.
The L/C/R speakers are all up front, so without the rear speakers, it's rather annoying to hear everything in front of me.
