Um, no, fdisk is to repartition the drive. format is what you use to format a drive.[Tripod]MajorPayne said:You reformat by using an Fdisk utility (DOS-based)
haze said:Yea, today my computer froze on me while playing counter-strike (as usual), and after it wouldnt allow me load up windows, it'll just say "\windows\system32\something". So i called DELL and they told me i had to reformat my comp, so they lead me through it and it fixed the problem. So i learned how to reformat my comp before i was able to read this forum, so thanks anyways.
That_Sound_Guy said:Dell lead you through a reformat over the phone...... right.
Reformats takes hours to do and no DELL support person I ever talked to would even have a clue on how to get started on that. you sure it was a reformat?
