What is my post count
Status
Not open for further replies.
djohn3853
Every time I try to reply in the Hot Deals section it says you must have more than 50 posts. OK, I get it. But what is my count? Maybe I'm blind (and I did search for posts about post count) but I can't find it. Little help?
Thats hilarious. My profile is probably the first place I checked. Guess what? Its not there (unless as I said, I'm blind). I'm not saying you're wrong, you are correct, but its under my public profile. I find that weird.
It's right there, I have no idea why you can't see it.
Yes, I now understand that its right there. What you did not understand was my response. My first thought was to check my profile. How do you do that? You click on User CP up top. When you do that and click on edit profile...its not there. You have to click on your own name in the post and then click view "public" profile. Why would it be in your public profile but not show up when you view your profile through User CP? Granted they wouldn't want you editing your post count, but they could easily make it so you couldn't while still giving the info.
Ah... simply click on your user name in this thread. A menu will slide out and then click on View Public Profile. It sort of hides.
That should get you where you need to go.
I don't see a problem here. You know where to find your postcount...it doesn't need to be reported in multiple areas.
Status
