In general, the Suprim are higher clocked from MSI with more power and possibly better cooling. Also, the Suprim may have dual bios or "Boost" switches on the cards.What is the SUPRIM line in the MSI Nvidia 3000 series line up? I've been over the specs and I can't discern what is different, if anything.
How does it compare to the Gaming X trio line?
Better cooling part is subjective. On the 3000 series the Suprim X 3080 Ti had the worse cooling solution when compared with Gigabyte Eagle 3080 Ti and Palit Gamerock 3080 Ti I had.Thanks. So 1) better build quality 2) higher clocks 3) heavier/larger 4) higher power draw 5) better cooling
