*tears hair out*
I'm typing on a PC that ever so often will pop up an error msg "The driver detected a controller error on \Device\Harddisk2\DR2. " I have 2 hard drives that are sitting unplugged in my tower. And a power supply that seems like it's on its way out.
This is #3.
First two were Antec TruPower 430W. After the 2nd one I figured I wouldn't mess around anymore and went with a Sparkle 550W with 36A on the 12V. Why 36? for the 6 HDDs, 2 optical drives, 9500, overclocked CPU and everything else.
This is starting out the same as the other ones.... The drives clicking and resetting, the PC freezing randomly. Each time it was solved instantly by a new PSU, but 6 months later it would start all over again.
I run the PC 24/7 and the drives are almost constantly being accessed, but is this really such a load for a quality 550W PSU to handle? Can there be something else that is causing my PSUs to die so readily?
Also it seems like I'll need a new PSU soon enough too.... I'll probably be going with PC Power and Cooling, but it would suck royally to drop $200 on a PSU that might be plauged by the same problems if the drain is coming from some place else. Has anyone had any similar issues?
This is #3.
