what is better c9 or c10
paco2013
Hello guys i have 32gb of this memory corsair dominator platinum cmd32gx3m4a1600c10
currently running at 1866mhz c10, but what would give a bit more performence, running at 1600mhz c9 or leave it like it is.
1866 cas 10 would probably give slightly better performance than 1600 cas 9 (the increased cycles per second, mhz, offsets the slightly higher latency), but it also depends on the other timings.
Try both settings and benchmark them. Then you will know for sure.
