What is a Pentium S?
towert7
Hi all. I work for my local school.... and we found a old box. I guess it used to be our web server, DHTP server, plus a few other things.
The thing is running some version of linux... and when it posts it says Pentium-S @ 133mhz.
I would assume that it would mean slot... but its not a slot... just a normal chipset by the looks of it.
Did intel ever produce a Pentium chip specifically designed for servers? i did a quick search on intel.com and found nothing.
~Thanks
ah, so its just another name for a regular pentium...
Hm, if that's the case i feel rather foolish.
Actually it refers to only select Pentiums with a SINGLE VOLTAGE in the core. The Pentium MMX (P55) generation had two internal voltages in the core.
