What is a CMOS checksum error?
RancidWAnnaRIot
EspantaPajaros
Hello,
I was fiddling with this old mobo i had in the closet.. and when i fired it up it posted (the beep).. but then it said.. CMOS check sum error..
what does that mean?
all i had instaled ws a vid card RAM and CPU
I think that means you need a new CMOS battery. Try changing some BIOS settings and restarting. If it resets automatically you might need a new battery.
Usually get that when the CMOS has been reset or the battery has been taken out. Maybe it was shutdown improperly or something before? Other than those, not sure what it could be.
I see i see.. well it's benn sitting in the closet for some time.. my guess is the battery is dead.. whatever.. i was just wondering.. thanks for the replies.
take it out and put it back in 1st, sometimes they pop loose, i pop them out if I mess up an oc and the computer will not boot, I once screwed up my math and took a 1.3 ghz celeron up to 2.9 :rolleyes: poped the battery and its all good, radio shack sells them if you need a new one $2-4
YOu changed RAM ... so it's checking it's saved settings, and it has the wrong RAM value wrong ... just go to setup ... reset ESCD, and save ...
