icthus13 said:Celerons are also teh suck.
Warriorprophet said:AFAIK the only time celerons were "pentiums that couldn't cut it" was the first P2/P3 cores. In the case of the P2 they were chips where some of the cache was actually bad, in the case of P3s, specifically coppermines, there were still some that had less working cache, and also some whose cache couldn't run at full speed (syncronous with CPU clk).
But all P4 based celerons are sepperately manufactured cores, and all current product families are manufactured completely sepperate, and most at entirely different fabs from one another. I've never heard anything of the middle/inner/outer track theory, afaik whole wafers are made of the same product, though similar patterns may be observed in speed bining, but with the current fab technologies you're looking at a much larger percentage of stable yield qualities, so even that occurance should be minimal.
I didn't think about the mobile P2's, completely forgot.FreiDOg said:Some of the Mendocino core PII's are no doubt Dixons (256k on die L2 mobile PII).with failed cache.
****snip*****
This is absolutely not to say Intel doens't produce dedicated Celerons, they most certainly do. Relying on screwups to fuel CPU line isn't a very smart thing to do, but niether is throwing away a die because 9 lines of cache have errors and you only have 8 spares.
IdiotInCharge said:The Celeron A's were the FIRST Pentiums with an on-die cache- the concept was later extended to the second generation Pentium 3's, but the first Pentium 3's were the same as the II's, with external cache.
0ldman said:As for the Celeron with its own line, I never said only the bum P4s made it. My understanding was the Celeron was the outside of the wafer, more likely for failure and lower clock speeds, not necesarrily a bum chip. Similar situation to the Thortons vs Bartons using the same fab. Not all Thortons are broken Bartons. Some are 100% functional as a Barton, just snipped, relabeled and sold.
I may be wrong, but that was the way I heard it
felix88 said:actually, the Pentium Pro was the first with on-die L2 cache.
anyway, Celerons are good chips for people on a strict budget, especially the new "D" chips.
Codegen said:Are the Celeron Ds Prescott? I believe so, just checking.
0ldman said:Bottom line, you can't have Corvettes without Corsicas... well, ok, you can, but something has to be in the place of the Corsica, Chevette, etc...
You need a value chip to help set the value of the performance chip and vice versa.
Catsonar said:Sorry but I hate Celerons, and now AMD made a crap processor as well the Sempron, they should of kept the bartons to compete with the celerons. I like intel for other inovations but the celeron, did they pick this out of there asses.
512. But they need more oh-so-badly..icthus13 said:Yes, but with only 256k of L2 cache.
Darth_Fluffy said:512. But they need more oh-so-badly..
pureevilmatt said:My media server/router/firewall PC has a Tualatin Celeron 1.4gHz, and it still outperforms my roommate's Athlon XP 1800 in most games, and that's with lowly PC133 ram. It also overclocks it to 1.75gHz(at which point it's probably compares to a 2200+). It never goes above 40C. It only recently started having trouble with games. It plays FarCry perfect, but doesn't do so well with Doom 3.
Not all celerons are crap. For the price I paid for that chip almost 4 years ago, all things considered, I'd say it's the best processor I've ever owned.
The P4 Celerons however, are not so good. As mentioned previously, they've been neutered in far to many ways. However, they're still a decent price.
OldPueblo said:Celerons have always been based off of the "P" core, they've never been their own core design. They started with the P2-based celeron, then made a P3-based celeron, P4-based celeron, etc. So you can't really just lump them all in the same boat, unless you just want to say "They ain't a P processor." The P2 ones with the overclocked FSB were basically identical in performance to their P2 older brother. Since cores change, they have found different ways to beat it down. I would say there is the biggest gap between the P4 and the P4 Celeron in terms of performance/whats been stripped down. BUT, the P4 celerons (Celeron D) are by no means slouches and I would happily recommend them to severe budget gamers that want an Intel chip, Mom and Dad's machine, etc. As for the Pentium M, its a whole different ball game and the only Celeron like it is (surprise) the Celeron M.
OldPueblo said:What do you think the Semprons are? The socket A ones are simply AthlonXP's renamed.
No, not at all. It's obvious that you didn't look at the benchmarks, because you'll only see a 5% difference at best. Usually, it's in the neighborhood of 1%.Catsonar said:Dude i knew that, but the rename cores have only 256k cache, which really sucks when compared to a barton
