What in the Heck could be wrong now?
I got my MSI Neo2 stock with bios 1.2 I don't know which flavor of 1.2 but thats what it had. I did the live update to 1.3, and that caused some problems with changing settings in the bios (HT) it would hang. So, someone suggested that people were having problems with doing that with a windows update of the bios, and just to do it the old fashioned way. So, I found on the MSI forums, that alot of people liked bios 1.23, so thats the one I got. Alot of people seemed to be having problems with 1.3. I got it from here: www.weckstrom.com - /msibios/ Anyway, everything went fine, 98SE bootdisk, blah blah blah, I figured otu which dirve the ramdrive was, C:\, then copied the flash and the bios to the drive, and flashed it. I backed up the old bios as well. NOW however, when it boots, it goes to where the realtek GIGA lan or whatever the hell it is, and if the ethernet cable is plugged it, it starts some sort of DCHP or something test, and then tells me it could not load someting from the PXE ROM, and that I have an invalid partition table. IF the cable is NOT plugged while booting, then it just goes straight to telling me that it could not load from the PXE ROM, and then invalid partition table. I didnt change anything at all, and nothing is unplugged. What the hell happened? It said flashed fine? Well, I decided to just put back the backup bios on there, but it wont even act like it's booting from the floppy? I put the 98SE disc in there and the light comes on, but it just goes to DMI Pool Data and then starts all that shit again. What in th hell do I do now?
sounds like your boot order is set to network adapter first. change it to cdrom or hard dist.
And why would you download a bios from some unknown site? Stick to DL'ing drivers and bioses from the manufacturer.
That site is used on almost every reference to a bios availability from MSI forums, its fine. I changed the boot priority, ect. boot order, pushed f11 and changed that, nothing seemed to work. However, just now, I just moved the SATA cable for my raptor from SATA3 to SATA4 and now it works just fine? Like nothing was ever wrong? What in the world does that mean?
Oh ok. I just see so many references to beta bioses from randon sites and people dont realize the harm in using one of these. I can understand video drivers and such as they are easy to uninstall but a bios isn't some to play around with to much.
But to answer your question - I dont know. But at least your PC boots now!
