Pagan Wizard said:What size fan did you install?? Looks like a 120mm........pretty expensive hole saw.
Yup, it is a 120mm fan. Had to go with a 4.5inch holesaw which is the closest size and costs about 40$ CDN. It is pretty expensive but I'm going to be using it over and over. Already done several other 120mm holes for my case mod project so it pays off in the long run versus using cut-off wheels. And yeah, the drill press is great.Pagan Wizard said:What size fan did you install?? Looks like a 120mm........pretty expensive hole saw.
sirholio said:same here with the apartment thing. Now that I have a house, I find myself buying all sorts of cool things to work with.
The hole saw doesn't look that expensive. Now the drill press... that's another story! If only I cut enough holes to justify spending the money on a press...
Agreed. Since I had the thing clamped down, I wasn't really anywhere near the actuall drill but I'll deifnitly keep that in mind.ashmedai said:He's right, if they get caught on something it's a good way to get horribly maimed.
westrock2000 said:I use to build speakers in the back room of apartments we lived in, I would just work during the day while both neighbors were at work (I work nights). I can only imagine what the cleaning crew thought of after we moved out and vacuumed up a whole trees worth of sawdust out of the carpet![]()
Depending on where you go (Northern Tools, Harbor Freight, Home Depot), you can get a bench top press for $70-$100. Should be enough power for most projects. You can always justify the price if you want to![]()
