what hdmi cord do i need for an LGCX 65" TV?
i'm getting an LGCX 65" for a tv. i'll be hooking up a high end pc to it, and by the time i get the tv the rtx 3080 should be out.
and i plan on hooking an xbox series x to it.
what specific hdmi cable should i be using? do i just look at the hdmi package at the store and make sure it says HDMI 2.1 on it? and does it matter what length of hdmi cord i get?
There is no official spec or certification for HDMI 2.1 cables though some advertise their cables as such. Others use terms like 4K 120 Hz or 8K60 or even 10K. Length matters once it gets above 2-3m so if you can, keep it short. Cable quality matters most when you are using longer ones.
