The experiment are interesting is as far as are a heat pipe cooler better at moving heat from the CPU contact surface than a conventional water cooling herd are, if it is, then i assume you could combine the 2 for a better performing system.
Heat pipe to rip heat off cpu and transfer it to a larger surface where water will take it to the radiator to be dissipated into air.
Just hoping it can be done with a much smaller fin stack than a full blown heat pipe cooler.
