onewheeldoin200
- Jul 4, 2004
Okay, I was playing with cpu stepsizing in my bios, set it first to 166mhz (from 133) and when it quit booting to windows I set it to 150mhz. I left all other bios options the same as before. After trying to reboot, I get an error message "Disk read failure. Press ctrl alt del to restart". This message comes on just before windows starts loading. The drive seems to be detected just fine right at initial startup.
Now, I tried booting with a cd, and that worked fine, so I tried swapping the cd/hd ide channels (1 and 2 respectively). Nope, cd still worked, hd didn't. Okay, so I tried swapping power cables from the cd/hd. Same result. I then plugged in an old maxtor drive I had kicking around (no boot data on it) and got the message "Disk boot failure. Insert system disk and try again".
What the hell happened? Is my drive gone for good?
The odd thing is I've never had a drive crap out instantly like that. It always gives me problems first. For the record it's a WD Caviar 205BA (yeap its like 10 years old, but it outlived 2 maxtors and a seagate).
Any advice/light shed on the situation would be met with tears of joy.
edit: the mobo is a soyo dragon kt333 ultra, running an athlon xp 2800 barton
