The list is quite long but the games that are worth playing are:
Mirror's Edge*
Cryostasis*
Mass Effect
GRAW 1 & 2
Unreal Tournament 3
Medal of Honor Airbourne.
Gears of War
Age of Empires III
"Perform better"? Well, it will look better. Whether it will cost you performance depends. It can cost you FPS if you are PhysX set to run on your nVidia video card and your video card is maxed out on performance (for example, when running high resolutions). In that case, switching it to the CPU rather than the video card may get your FPS back, if your CPU isn't maxed out.
You can even put in separate video cards and set them to only do PhysX, which takes the PhysX load off the main video card. A FiringSquad review suggested a 9600GT was enough to run PhysX in that case. When you get into SLI setups, things get more complicated and I don't know the answers.
If the game doesn't support PhysX none of this matters, and PhysX is only done on nVidia cards at this time.
The latest drivers from nvidia help with this fact, running SLI plus a third GPU in my rig, I was able to select my 8600GTS as the PhysX card to do all the fancy effects in GRAW2. I haven't played enough to tell you if there is a FPS hit or not.
This is a very nice feature though that you can select which card you want as the main performer and/or which one to do PhysX, that is if you have a second or third GPU. Also I would like to say in SLI you can run dual monitors now as they also enabled that feature in the latest driver version.
When they showed off the Mirror Edge PhysX comparison, it looked nicer but they never claimed an FPS increase. I don't know if in a situation where PhysX was offloaded from the CPU or GPU's, if there would increase FPS. I would think theoretically that it would but I haven't read anything that showed an increase in FPS.
