what fitting is this?
AP2
Can any one tell me or link me to the 90 rigid tube fitting? Ive searched all of Bitspower webpage, but can not find it.
looks like a non rotary 90 rigid fitting.
any help would be awesome.
nice find! its the first one PD1 linked up. i dont know if i would want a fixed 90 on my cpu block? what if you cant get it tight enough in that position? id be afraid of it leaking. a quality 90 rotary would be a much better option imo.
bitspowers webpage is useless in finding anything unless you have a part number.
PD1 uses his googlefu:
*Waves hand; " These are not the fittings you are looking for, nothing to see here, move along*
