What exactly is a spacer?
LeArN2LiVe
I need more clearance between my MCR220 and my Antec Solo to get my DVI cable in. People have been reccommending me to get a spacer to gain more space. However, I am absolutely confused as to what a spacer is, what it looks like, and what it does.
If someone could give me a link or picture to a spacer and where I can pick one up, it would be greatly appreciated. Thanks!
If a radbox isn't enough clearance, it's probably time for some threaded rod, nuts, loctite, and a little homebrewed ingenuity
Pics of your predicament would help...
I don't have a Radbox. :(
In theory, using longer screws *should* help me but I'm afraid the weight of the radiator would snap the screw in half.
Get yourself some 8-32 (might be 6-32, take a screw you are currently using) machine screws in what ever length you need and use those, unless you are using your rad for a seat you will not break (or bend for that matter) those screws.
Put simply, a washer is a spacer. It adds a space between a screwhead and the item to which you're screwing into.
What people are saying is use longer screws, and add a spacer between the case and the radiator that the screw passes thru (eg: a 1cm length of narrow metal tube, or a stack of many washers, or a small chunk of wood with a hole drilled thru it for the screw) so that when you tighten it all up, a space remains between the rad and the case because the screw can't tighten the rad all the way up against the case due to a spacer being in the way.
at a Home Depot or Lowes hardware store you can buy 3" screws and some 1 inch long nylon spacer tubes (and 1/4 and 1/2 inch as well), just stack the spacers between the case and rad. If the 2 3/4 inch space is not enough you can special order some 4" screws, #6 x 32 thread machine screws being commonly used. The strength of the screws is not a problem, they look skinny but the sheer force is high enough for this application.
even better get a 4 foot 8-32 threaded rod for $2 which you can cut into posts, and a handful of nuts $3 (4 nuts for each post) preferably nylon so they wont move. put one end of the posts you made thru a fan mounting hole on the radiator (if you have mounting holes, otherwise get a thinner threaded rod so you can push it through the fins of the radiator, and big washers). put a nut on both sides of the radiator so the posts are tight, then screw the other ends, in the same fashion, to somewhere on your case.
Spacer
In this case that one has a head at the top (the little red square) and a a screw that can screw up from the bottom, which you can't see. You can buy all kinds of widgets like this at your local hardware store.
