What exactly is a DPS unit
Hate_Bot
Ive heard that when You purchase the Gigabyte NF4 SLI mobo yo get this
(The one on top) I was wondering what exactly that is and what it does.
Thanks
Thanks
"DPS" stands for "duapl power supply". It's a switching power supply module.
Normally, modern motherboards have a switching power supply on-board that converts the 12-volt line from the PSU to VCore for the CPU and the memory supply. The BIOS controls the voltage setting of this switching supply, and that's how you select the voltages on your system to match the CPU and the memory.
Before the switchable regulators were available, 486 and early Pentium systems had a voltage-regulator module on board. You'd have to get one that was compatible with the CPU you were using.
The DPS is a similar idea, though Gigabyte has made it a little more interesting. Some of their motherboards alow you to run the DPS module as a redundant supply to the on-board switching regulator. They can run in parallel to double the available current, or the boards can be configured to detect a problem and reboot using the other regulator.
If you ask me it's of little practical value and just a marketing gimick.
.B ekiM
